TractorLinks.com
Show Parts for Model:
Re: Lock washers and grease zert questions
Yooper Farmall
04-05-2013 09:15:12
Hal, thank you so much for looking, I really appreciate all your help. I called my local Case-IH dealer, they initially could not find that part number, then found reference to it and showed it being changed. They only had access to the 3/16" press in style. I might end up having to go to a junk yard to find them.
Thanks again.
Don
farmallhal
04-05-2013 13:54:25
 Re: Lock washers and grease zert questions in reply to Yooper Farmall, 04-05-2013 09:15:12
Don, I sent you an email through this forum, Hal.
Yooper Farmall
04-05-2013 14:10:24
 Re: Lock washers and grease zert questions in reply to farmallhal, 04-05-2013 13:54:25
I got the email, thank you. I'm on the phone with my Case-IH dealer now, they see the parts depot listing, they see quantity 7 for part 110 161 but the description is listed as "housing".
Your IH Super C parts catalog, what page is that part number listed?
Dealer also said if they knew exactly where on a Super C the zerk was used, they could probably track it down. Was it every zerk or just a specific one?
Thank you again, please don't inconvenience yourself, I'm sure I can find a work around.
farmallhal
04-05-2013 14:50:06
 Re: Lock washers and grease zert questions in reply to Yooper Farmall, 04-05-2013 14:10:24
It is reference no. 13 on page 201 and the part is described on page 202. My Super C parts catalog is TC-44B and Revision 4. There are two of them on the fast hitch. A lot of times the part name at the depot is not correct but can't be sure and don't know if they will work with the parts guy to get a better description or not. Your dealership will most likely know, Hal.
P.S. Both of these zerks on my tractor are identical with the hex shoulder.
