Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Replacing Transmission Seal on Farmall B
Daniel H.
04-04-2013 17:58:21
Item #9 in this diagram
You will also need gasket #2.
Also, that bearing is spendy, I would wait until you can check the one that is there before buying one. If it turns smoothly I would leave it alone, unless money is no object :wink:
This post was edited by Daniel H. at 18:03:26 04/04/13 2 times.
04-05-2013 08:32:29
 Re: Replacing Transmission Seal on Farmall B in reply to Daniel H., 04-04-2013 17:58:21
Thanks for the info! I haven't taken apart the rear end before. Will the gear shafts just slide out of the differential after I unbolt the rear axle housing from the transmission case, as well unbolt the drawbar? I have an engine hoist to help move things around, but I just don't know what I am going to quite run into when I start taking things apart.
