super a sprocket drive
susan A
i would like to know if a sprocket drive from a farmall b would fit a super a thanks hope you all had a good easter!!!
Yes it will fit. But if you want to use it to power any Super A implements, the sprocket will be several inches out of line.
ok i want to use it for a side dresser have a sprocket that came with it but you say it would fit the drive?
(quoted from post at 00:34:22 04/05/13) ok i want to use it for a side dresser have a sprocket that came with it but you say it would fit the drive?
Post a picture of it and it will help us answer better. It could be that you have the right part, and you think it fits a B. Pictures really help alot. If it is for a B, then it should fit, but might not work correctly as the B was designed with different widths.
this is it i found it on ebay and it says its for a B BN or A just typed in sprocket drive and its the 4 or 5 one down
I do not think so. The sprocket for a SA is completely different than the picture. Keep your eyes open and watch the sales and auctions. Restorers scrap and sell the cultivator parts on their projects.
