Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 560 hydraulic pump
04-03-2013 19:23:39
A leaky or stuck relief valve can mimic a bad pump. A pump wears around the edges of the 8 shaped housing. Often the wear is so smooth that it does not appear worn. Using a feeler gauge between the gear tips and the housing there should be less than .001" measured in all directions between the tooth tip and the housing. There are no rebuilders that ai know of due to the housing being worn as well as the gears there is little to actually repair without as much expense as making a new pump. Jim
