TractorLinks.com
Show Parts for Model:
Re: 560 hydraulic pump
dundeej
04-03-2013 19:04:20
I took the pump apart and it is only scratched on the metal and copper plate
pete 23
04-04-2013 10:28:44
 Re: 560 hydraulic pump in reply to dundeej, 04-03-2013 19:04:20
How about the diapragm, is it blown. Also, if bushings are loose it is shot. Relief valve is in regulator block and pretty much not a problem on those tractors not saying it cannot be scored and stuck or broken spring.
Janicholson
04-03-2013 19:23:39
A leaky or stuck relief valve can mimic a bad pump. A pump wears around the edges of the 8 shaped housing. Often the wear is so smooth that it does not appear worn. Using a feeler gauge between the gear tips and the housing there should be less than .001" measured in all directions between the tooth tip and the housing. There are no rebuilders that ai know of due to the housing being worn as well as the gears there is little to actually repair without as much expense as making a new pump. Jim
