TractorLinks.com
Show Parts for Model:
Re: Lock washers and grease zert questions
Yooper Farmall
04-03-2013 08:34:49
Thank you Hal, I see Fastenal carry's a 3/16" zerk, I'll try those.
The club tractor is an H, don't know what year but it did come in rear steel.
Thanks again
Don
farmallhal
04-03-2013 08:53:06
 Re: Lock washers and grease zert questions in reply to Yooper Farmall, 04-03-2013 08:34:49
The parts catalog might have a mis-print but this is what is called out for the frame rails in my TC-27E parts catalog for the Farmall H/HV.
For the left frame rail it calls out (4) 1/2" split lock washers and (4) 5/8" external tooth lock washers unless a HV model and then only (2) are required.
For the right frame rail it calls out (4) 1/2" external tooth lock washers and (4) 5/8" split lock washers unless a HV model and then only (2) are required.
I don't know why both sides wouldn't be the same but that is how the parts catalog has them noted common to the frame rails. If known how they were removed from the tractor I would suggest putting them back in the same manner. Maybe someone can provide some additional clarification, Hal.
