Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
1086 clutch
gbs
04-01-2013 18:47:21
ours is hard to feather its all or nothing other than that works fine was wondering if the boost cylinder could have something to do with it
pete 23
04-01-2013 19:55:34
 Re: 1086 clutch in reply to gbs, 04-01-2013 18:47:21
Cab mounts are critical on those models. All of them. As you can see when you depress the clutch the cab mount compresses. If they are shot the whole cab moves. There are also two different style clutch pedal linkages. Early pivot mounts on transmission case, and later on cab. This was changed to overcome grabby clutch. Also, a misadjusted dump valve will cause a lurch so adjust so red light goes off just before clutch starts you moving.
Copyright © 1997-2015 Yesterday's Tractor Co.
