Anonymous-0
What would be the best thing to used to clean outside of radiator before painting .would muriatic acid mix with water
Work
Soap and water then hose spray to rinse. Paint should be thin coat of black spray from a radiator shop. Not thick as it will inhibit heat transfer. Acid will eat some of the metal, it needs all it has. Jim
A source
