Vally Farm
What is the correct fluid for the Hydra-Touch system? Operator's Manual gives nothing. Also, Tranny fluid? book says Hi-Tran, or a mix of T/A lube to 4 gal IH Hyd fluid, SAE 10,20,30,or SAE 80 or SAE 50 or SAE 90. :?: Whole lotta choices there!! I'm in upstate NY and use the tractor all year 'round if that makes a difference. Am now using regular hyd. fluid, but the pump screams for 15-20 minutes in the cold weather until the fluid warms up. :shock: Just blew out the O-rings at the pump, and wanna make sure the right fluid goes back in. Tractor has a loader plumbed into the Hyd. system, with P/S and Fast Hitch. Also, might add a remote valve too. Thanks for any help. Mike
