Anonymous-0
Ho much is a M D worth, it runs front tires good rears weather checked tin good thats all I know Thanks Pete I think its a 48
(quoted from post at 15:23:39 03/21/13) Ho much is a M D worth, it runs front tires good rears weather checked tin good thats all I know Thanks Pete I think its a 48
The number of people today looking for an M gasoline tractor is greatly reduced from what it used to be. The MD I would think is a bit of a collectable, but they do have a bad reputation with head issues and overall engine maintenance problems. The average back yard mechanic is lost around them. On a good day with a nice paint job, running well and with good tires, you might see $1500 to $2000. Now if you had a SMD the value would be much better.
Have one setting in the shop that needs a overhaul kit and they are 3600 dollars. Tore it down and found out what I needed, so still setting there.
