Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Farmall 826 Hub
03-22-2013 05:42:11
If the hub isn't broken...
Slip a shim made from roof flashing in between the hub and axle on the keyway side to give the wedges a better bite.
The wedges should be out toward the outside of the hub, not sucked into the middle. We had that problem with the 1066. The wedges would suck right in and the wheels would slide if you touched the brakes on a turn.
pete 23
03-22-2013 10:24:03
 Re: Farmall 826 Hub in reply to mkirsch, 03-22-2013 05:42:11
Good advice with either type wheel. If wedge lock, which I doubt a new wedge may fix problem also. Thing to look at also is see if the rounded part of wheel is touching the axle. It should not as this prevents solid contact on the flats of the axle. A shim will solve that problem or some machining to the hub will also. M&W dual hubs were bad for that. Guy had two men on about and 8 foot bar, still walked. I showed him what to look for , he had them machined and just normal tightening kept them in place. Had several IH wheels with that same problem.
