Need a Wheel for Fast Hitch Plow
RTR
I am in need of several wheels (like the one pictured for a fast hitch plow like this. It fits a Super A-140 farmall tractor. I have (4) of these plows and 2 of them have these rubber tires. Upon trying to air up the tire and reinstall it, the rim busted along the inside of the outer surface. I got the other tire and rim and was going to use it and it did the same thing.
I got a new Universal tire and rim combo from Harbor Frieght and it isn"t the same and will not work.
Where can I find/get some of these???
I have a plow that looks a lot like that one but it does not have any tires on it. Not sure if it should or not but that makes me wonder
Old....Both of the plows with the tires look original to me. I don't know what else would go there. It seems like it serves as a "jack" for hooking it up. One of the plows came with a 1976 Farmall 140 tractor. The other, I don't remember.
The one I have I got from a neighbor and before he got the place the neighbor before him had a 230 or 240 not sure which that he got the plow with but never used it
Are these two piece wheels that are bolted together with three bolts then attached to the hubs using a different three bolt pattern? What is the tire size as I have seen both 8" and 9" tires on wheels as I have noted. I have found that the 9" variety is more common then the 8" ones which I finally located for my IH No. 11 hay rake, Hal.
That plow is similar to the C-200 which is 2-point fast hitch for Super C, etc. Don't lose or destroy that rim; it is a 2-piece rim that you cannot replace in my digging. My only success was getting a new rim from the local tire store. Then take it to your local welding shop and have them use the outer from the welding shop and the inner from the plow to make one good one. The inner from the plow is critical to mount to the axle shaft. Good luck!
I have one with a small 2-point hitch that came with my 200. The wheel is a true gage wheel and will also serve as a jack stand when the plow is not in use.
If you want it fixed RIGHT NOW, I say just cut the center out of the bad wheel, cut the center out of the Harbor Freight wheel, and weld the good rim from the Harbor Freight wheel to the center from the bad plow wheel.
Just take the tire off the Harbor Freight rim first.
The plow wheel is no good anyways, so there's no point in saving it.
Otherwise, you'll need to provide more info about the size of the wheel and how it's mounted. Maybe someone will know of a suitable replacement if we have more than just a picture of it from a distance where we can see that it's round and black and has a greasy hub...
What size tire is mounted on the wheel you are making reference too? Is it one of those two piece wheels which mounts to the hub with three bolts? Is this something which you would offer for sale or just making reference too the fact they were used on a plow also? If available for sale my email is open, Hal.
Yeah, well I don't really see having a rim "made" would be very cost effective. Is there nothing for a replacement that is available?? Wonder where you'd find an equivalent that was maybe used on something else?? IDK which route to go or where to look other than having one made which is really not even feasable unless it were for show.
