Cub battery problem?
cubluvn8n
I just noticed today that my cub will not run without the battery hooked up. The battery cable worked itself loose while it was running and the tractor immediately died. Is this normal, or do I have something wired wrong??? Thank you for your help!!!
They call them battery ignitions for a reason.
Clearly you have a battery powered ignition system, whether it's an actual battery ignition distributor, or a cobbled-up magneto with an external coil.
Disconnect the battery, ignition system stops working, engine dies. Perfectly normal.
