Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: d310 fuelpumps
03-17-2013 12:53:56
EPVA distributor pumps had 3 versions, AR, BR, and CR. AR and BR had the delivery valve fittings at an angle while latest CR type had fittings that came out straight. Pumps will interchange but injection lines may need changed or old line bent as needed to fit. Also CR inlet and outlet line bolts are the same, while AR and BR use a pressurising valve in the return line. Bolts are the same size, don't get the wrong bolt at the inlet. May not start or will barely run if the pressurising bolt is placed at inlet banjo.
1968 403
03-17-2013 16:41:18
 Re: d310 fuelpumps in reply to Dieseltech, 03-17-2013 12:53:56
Thank you for the replys. I bought a 310 with the angled inlets and I have a good 310 injector pump here with the straight inlets. Just wondering if I could swap them if I need too.
