| Farmall & IHC Tractors Discussion Forum |
Topic: Single Wire Alternator
[Return to Forum]
| Author |
[Modern View]
| 5 Forward
03-15-2013 18:13:37
97.82.22.4
I have a 300U with a used single wire alternator. The previous owner was in the process of installing and wiring the alternator. I have installed a new amp gauge and completed the wiring. Upon startup and the alternator charging pegged the amp gauge at idle it continues to charge at more than 10 amps. My first thought was the battery is low but by now charging should be tampering off. Could the internal regulator be bad? |
[Reply] [No Email] | |
| K-Mo
03-16-2013 04:05:48
66.43.226.235
Re: Single Wire Alternator in reply to 5 Forward, 03-15-2013 18:13:37
| You don't say what the range of your ammeter is. If you have a 30 amp or less gauge, you can expect it to peg after start up. I use a 60 amp. Depending on the output rating of the alternator, it may still peg initially, but should soon tapper back. Alternators have a much higher output the the old generator. The smaller common Delcos are about 40 amps. If voltage on a fully charged battery exceeds 15 volts, the regulator is probably bad. |
| gbs
03-15-2013 20:09:42
71.51.255.47
| before you get to in depth with it ,try changing the battery to one that's known to be good,btdt with a ford 351 cleveland build for racing battery would spin it like a top ,alternator wouldn't charge less than 20 amps after several tests and plenty of trail and error attempts to solve the problem it turned out to be the battery, not common but it happens |
| 5 Forward
03-15-2013 19:11:10
97.82.22.4
| I ran a 10 gauge wire from the alternator to the load side of the amp gauage and a 10 gauge wire from the battery side of the gauge to the battery side of the starter solenoid. The gauge is in series between the battery and the alternator |
| Janicholson
03-15-2013 19:15:17
74.60.94.18
Re: Single Wire Alternator in reply to 5 Forward, 03-15-2013 19:11:10
| That is correct. A three wire is very easy, has no parasitic draw when parked, and starts charging at idle speeds. The one wire uses a modified voltage regulator that remains on all the time. Bob M wiring diagrams has the procedure for setting it up. If you become irritable with the one wire. Jim |
| John T
03-15-2013 18:58:39
71.54.160.151
| | That "single wire" alternator output wires up to the Load (NOT battery/starter) side of the ammeter, the same terminal that feeds battery voltage to loads such as lights and ignition etc. The other Supply side of the ammeter gets to the batterys hot ungrounded post, often by a wire down to where the big battery cable attaches to the start switch/solenoid. Often then theres ONLY ONE wire on the ammeters Supply side (to battery/starter) and maybe two (Alternator and wire to light/ign switch) on the Load side.... If all is wired right yet it drastically continiues to overcharge (keeps battery at say 15 volts all the time) Id say the Voltage Regulator is bad and that will cook the battery... On the 10SI 3 wire units that one small terminal was used to sense battery voltage, maybe the alternator isnt sensing true battery voltage John T |
| soundguy
03-15-2013 18:42:35
108.112.13.97
| also.. any chance it is wird incorrectly.. as like in an amperage gauge measuring total output of the alt.. vs as a center 0 ammeter measuring net charge / discharge ?? |
| Janicholson
03-15-2013 18:16:30
74.60.94.18
| yes. If you measure the voltage at 1/2 throttle with a charged battery, it should be 14.2 to 14.6 volts. 15 if cold. If more than 15 it will destroy the battery if operated for hours. Jim |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
