Remote hydraulic valve question for Super A or Super C
RTR
Say I have a tractor with a hydraulic bypass block on the
reservoir for a front end loader. Could I also add the remote
hydraulic valve that was offered for the super C and super a
tractors? That valve actually has its own manifold lines unique
to it. Will the lines bend enough to allow them to mount to the
hydraulic reservoir? If anyone knows what I am talking about
or has seen this done please let me know
No you cant use your lines to add a valve but you can get the plate that does allow you to add a remote.If you want to use the original valve that ran the fast hitch you still need to replace the lines that are made for that valve.
﹐what I am asking is can you install the remote Valve with the specific lines while the 1 arm loader is installed ?? The 1 arm loader uses a bypass block and I was worried that it all would not fit at one time.
So you have a seperate valve for the loader and you want to add another control valve if thats the case just add another valve in series with the one you now have just make sure its an open center. Or just get a double valve and use one for the loader and the second for remote.
I think it would work. You really have nothing to lose by trying if you already have the valve. Worst case it doesn't fit and you have to put the old lines back.
If you don't have the valve, IMHO they are difficult to find and expensive to buy. You can simply buy a generic open center valve and take the OUT line from the loader valve and connect it to the IN line on the new valve.
You dont want to use the original valve assy that was used on the SC with fast hitch it will not work. I worked on one that did that and it was a mess to raise the loader. mJust use the block then get a double valve assy then you can use the loader off one valve and remote off the other or just add another valve in series with the one you are using the loader for. The hy oil needs a path thru both valves then to the rockshaft assy on the tractor. The one i did some work on was a mess to raise the loader by pulling two levers the same time. Owner said he could use it the way it was but in the future mite have mw redo the system so it would work better.
