rebuilt 185 lowboy engine
tammy 1
New User
Local shop has a rebuilt engine complete except dist.They rebuilt it was never picked up they want 1200.I need one is this a fair price.
Ask to see the repair bill, sounds about rite to me. Irebuilt a D 239 , new crank shaft, Pitons/sleeves brgs recon head injecors pump Fellow never came foud out he scraped tractor and did not want engine, was glad to get price of parts out of it.
s
I guess I should qualify that. It depends on what they consider a rebuild. If they ground the valves, honed the cylinders and reringed the old pistons its a few hundred dollars of work - with the engine delivered to them.
If they did a complete rebuild with new bearings throughout, pistons, valves, oil pump and they could have $1200 in it.
http://www.link_disallowed/international_harvester_tractor_parts_overhaul_kit_945147_3020_prd1.htm
(quoted from post at 12:22:29 03/12/13) I guess I should qualify that. It depends on what they consider a rebuild. If they ground the valves, honed the cylinders and reringed the old pistons its a few hundred dollars of work - with the engine delivered to them.
I agree. If it was a [u:5892199180]complete[/u:5892199180] rebuild they likely bored the cylinders oversize, also.
In my area that would be high, but in a lot of areas it is in line with the cost to do a complete overhaul on a C60. One thing to pay attention to is what you are going to use it for. If you want to put it in a cub, check that the crankshaft has a hole for the pilot bushing, some of the numbered lowboys did not.
