300U hydraulic vent
Bkpigs
Anyone know where I can get a hydraulic vent for the reservoir on a 300 utility? The cap got shoved down over the stem on mine. Looks too thin to weld but will give it a try if no other option.
Yep, I think that is how it got broke. I am gonna put washers under the rail mounts to give it a little more room.
I agree with KS guy33. Silver solder will also work, as will lead free plumbing solder. Pull it out straight bu lifting all around the edges evenly while it is screwed in. Then unscrew and braze or solder. Jim
