wreck IH340
Don Ober
still have a lot of stuff left on my 340 that I rolled I ll give it another week or two then scrap it when the weahteer breaks,just hate to junk that many good parts.But not going to have it sitting here reminding me everyday.
How is the linkage from the valve bank to 3 point cylinder? I think mine could use replacement. My seat is also not that great.
Let me know if either of these are in usable condition.
Thanks,
Bart
Bart are you talking about the hyd lines that go back under seat our the linkage that goes to the valve bank?I think both are good. Don
I believe it is a line that goes from the valve block in front of the shifter under the seat to somewhere in the back. Currently I have to push the linkage on top of the valve block while the 3 point lever (on the right by the fender) is all the way up in order to raise the 3 point the entire way.
My thought is that this line needs adjustment or replacement. I was waiting for a warmer day to tinker with it though.
might just be that the hydratouch is stiff mine done that in cold weathewr till it warmed up,was told I just didn t use it enough to keep moister from get in it.the valve bank and linkage on mine are fine the 2 remote handles did break off. Let me know if you want anything. don
