ksguy33
On a IH 300 U, does anyone know if there is more than one gasket for the hydraulic reservoir, I took mine apart to clean the screen, and ordered a new gasket by IH part number 361875R1. The holes just aren"t in the right places. Any idea"s Thanks Keith
I pulled the top off my 350 U a few weeks ago to check the strainer. Cleaned the surfaces real good and used a real thin layer of permatex gasket maker on it.A lot of times someone will use way to much silicone in place of a gasket it doesn't take that much. Someone had removed the screen inside the sump and install a inline strainer in the line going to the pump. Checked it today nothing in it. Now if I can just get the leaks stopped on the power steering.
