TractorLinks.com
Show Parts for Model:
Re: Stuck engine
wilson ind
03-09-2013 07:06:45
Olds heet and atf in addition If you have a crank for the front of engine try this . I have placed handyman of Bloomfield jack on crank , dont raise the wheels or bend the crank . Just some pressure, then tap with maybe 2 lb ( foreign folks use 1 kilogram)hammer. My attempt at humor. The vibration and time with atf will usually work . Be sure to leave all plugs out. This vibration is required for the guarantee for Engine Release a product for stuck engines.
Brent Holland
03-09-2013 08:08:30
 Re: Stuck engine in reply to wilson ind, 03-09-2013 07:06:45
I tried the crank... but it is somehow defective and would not ingage the crank... so I just put a pipe wrench on the pin in front of the crank and put a foot on it with no luck (Note that I did use a standard pipr wrench and not a metric). Thanks for the input... I'm taking it all in - with patience and calculated moves I'm hopeful for a good result.
old
03-09-2013 08:49:17
 Re: Stuck engine in reply to Brent Holland, 03-09-2013 08:08:30
I have 3 Hs that run and 2 of them where locked up from sitting a long time and freed up with the ATF. I also have one that is still locked up but I have not really tried to free it either. Set a good 12 volt battery in it and use short fast taps of the starter button. If you see the crank move any at all pull the plugs and try it again. If the crank moves any good chance it will free up
