| Farmall & IHC Tractors Discussion Forum |
Topic: Re: Stuck engine
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| rustcollector
03-08-2013 17:22:29
70.195.194.8
I am leery of using the tractor hydraulics as described below. Before trying to turn the engine, remove the valve cover and the rocker arm assembly so that if a valve is stuck, you don't bend a push rod. Lub the valve stems and tap lightly with a hammer to be sure the valves are not stuck. Once the valves are all seated, use the hydraulic pressure method but with hydraulic oil, ATF or other favorite concoction in the cylinder and compressed air pressure and let it set for a few days under pressure if necessary would be my first attempt. It would help to lub and pressurize each cylinder for a few minutes, then letting the cylinder that is just past TDC sit with air pressure. Hydraulic pressure from another tractor is enough to bend or bust engine components (about 10 times high combustion pressures). |
| Brent Holland
03-08-2013 17:34:59
166.147.104.29
Re: Stuck engine in reply to rustcollector, 03-08-2013 17:22:29
| That's a great point... and another good reason to fill the cylinders with sparkplugs installed (once the water is removed), because it would cover the valves as well. When I did my grandfather's pickup I used the housejack weight to apply constant torque to the crankshaft- but not too much force to bend things. They did try drag starting that truck with no success - probably a good thing that didn't work. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
