TractorLinks.com
Show Parts for Model:
Re: Stuck engine
gene bender
03-08-2013 17:04:30
When you have the plugs out you can see some of the cycl wall and if its rusty you need to pull the head if the cap was off the exhaust you also have some bad valves so you will be better off pulling the head now as all the snake oil in the world will not fix it so you can save a lot of time and messing around and just pull the head and get started on the fixl
Brent Holland
03-08-2013 17:10:42
 Re: Stuck engine in reply to gene bender, 03-08-2013 17:04:30
I agree, but the saddle club is working on a limited budget. After seeing all those restoration pics I'd like to just start tearing it down to the frame. But they just use it once a month to smooth out a small arena. It doesn't have to pull strong, or work long hours, or even burn particularly clean. It just has to work a few minutes a month. I do see some wisdom is letting it run a short while then immediately dropping the oil to drain whatever water, rust and old oil is there (liquid sandpaper).
