Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Looking at a 756
[Return to Forum]
picassomcp
03-08-2013 16:42:03
50.107.38.145
I am looking for a diesel tractor to replace my 706 gasser. My gasser does all the things I need it to but my gosh the gas it uses. I have tuned this baby up and try to keep my RPMs no higher than needed. I use it strictly to run my 9' haybine and it also runs the round baler. I may be plowing up some ground soon and could only imagine the gas it would burn plowing. I have found a 756 diesel close by that I am considering. I have read reviews from this site and by the sounds of it they are pretty good tractors. Rock solid engine and easy on fuel. This tractor is on a middle mans lot, he bought it on auction so there is really no finding out the history on this tractor. It has 9700 hours on it which is quite high on an original engine. Can't tell if the engines been worked on or not. Its clean as a whistle so likely been pressure washed, cant tell if there is any leaks or not. I can see a bit of antifreeze leaking from the rail just above the exhaust manifold. Looks to be a easy gasket to replace. The oil has been changed recently, can't tell ifs theres any sign of water in it or not. The price is right at $4800 but I just am a bit uncomfortable with all the unknowns here. Theres gotta be a reason that the last person who actually used this tractor sold it? I haven't heard it run yet, but I'm guessing that the engine needs rebuild. Whats a good way to tell if it needs rebuild or not while its on a dealers lot? Any other potential concerns about a tractor like this? I would like to try it out before committing to purchase but this time of year thats pretty tough. Lots of snow and frozen ground here in central MN. Tires are good but not matching. Ugly cab, no glass in it. But the tin work is very straight, needs paint. Seat is tough. All thoughts welcome and appreciated. Thanks
[Reply]   [No Email]
DeltaRed
03-08-2013 20:08:06
71.208.220.227
 Re: Looking at a 756 in reply to picassomcp, 03-08-2013 16:42:03
9700 hrs is not a lot of hrs for that engine.It should have plenty of life left.Mine has close to 11,000 and is still strong and uses no oil.That 310 should run 15-20,000 hrs.On the starting issue,you must use the 'fuel dump'(enricher) or it will not start.My tractor will start well even at freezing.The 4800 is a fair price for a decant tractor.I would be more concarned about the TA than the engine.If you do buy it,you will love it,as I do mine.I would welcome the oportunity to talk more....Steve
[Reply]  [No Email]
Baelee05
03-08-2013 20:05:20
166.137.100.30
Hell of a good tractor with a good motor. However, the motor and injector pump can be very spendy to overhaul and hard to find parts for.
[Reply]  [No Email]
big a
03-08-2013 17:03:51
70.198.2.59
Sat lots of hours on a pair of 756's. loved them dearly.
First thing to do IMHO, would be, with engine cold, as in not started for a few days, crack the oil plug loose, and check for any antifreeze coming out past the threads. The Neuss engines were problematic for that.
Next, see how it starts cold, if injection pump is weak or not timed properly, they can start hard, also if down on compression due to wear. Valve recession can cause this too.
Don't be too alarmed if it slobbers fuel out around the exhaust manifold, common if they idle around too much, especially in cold weather.
Check shifters and linkage for proper adjustment, and all the other items just like your 706.
With decent care, that engine should have plenty of life left.
Oh yeah, stay on top of fuel filter maintenence. Seen lots of those inj pumps trashed by water damage, especially on machines that sit unused a lot.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
