Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1988 Case 7120 - excessive blow by
njfarmer
03-08-2013 16:27:27
I have a 89' 7130 on the farm and last year it developed excessive blowby. To make a long story short i found out after some investigation that the early model 7130's had a different injector that had problems and i had the injector tip blow up and torched a hole threw the piston. What i don't understand is why isn't the dealer that is selling the tractor fixing the problem as they get all there parts for wholesale and then he can advertise the tractor as a fresh rebuild and add to the value substantially.
njfarmer
03-08-2013 16:29:06
 Re: 1988 Case 7120 - excessive blow by in reply to njfarmer, 03-08-2013 16:27:27
You didn't mention it but, How many hours are on the tractor?
hours - 10,500
03-09-2013 12:38:33
 Re: 1988 Case 7120 - excessive blow by in reply to njfarmer, 03-08-2013 16:29:06
Well, it sounds like a fella would have to count on buying the cylinder kit, and maybe some injectors. 10,500 is alot of hours.
tanman_2006
03-09-2013 22:50:04
 Re: 1988 Case 7120 - excessive blow by in reply to hours - 10,500, 03-09-2013 12:38:33
My 8920 has 6K and some blowby and uses a little oil ~1 gallon in 2-3 days working hard. Head shop guy told me the engine is in great shape and just needs valves reset, did that. Sent injectors in for a rebuild (to a performance shop) got a little bit of a power boost on them, added fuel and a better set of wheels on the turbo. Next I bent the shaft on the 250 hp pto dyno and before I was pushing ~180-190hp.
These tractors can do some serious work when built right but are a solid work horse out of the box. I dont recommend adding alot of fuel with out a better flowing turbo for lower egt's. My egt's are actually slightly lower that before the valve job and 180-190hp dyno. I have mechanical gauges for EGT, boost, oil pres, coolant temp, oil temp, and fuel pressure (very informative, the bar gauges are junk imo)
pistons
03-10-2013 11:47:23
 Re: 1988 Case 7120 - excessive blow by in reply to tanman_2006, 03-09-2013 22:50:04
What are egt's? And yeah, I have read that though advertised as 150 at the drawbar, people often say they put their 7120 on a dyno and see them commonly much above 150.
tanman_2006
03-10-2013 14:05:43
 Re: 1988 Case 7120 - excessive blow by in reply to pistons, 03-10-2013 11:47:23
I was getting 1400*f before and 1300*f now. Those are highest I've seen not common.
Copyright © 1997-2015 Yesterday's Tractor Co.
