TractorLinks.com
Show Parts for Model:
Re: 1988 Case 7120 - excessive blow by
430WLPG
03-08-2013 15:09:55
I have fixed a ton of those, usually the pieces will work their way up to the top and bang around on the valves. And those valves don't have much meat for grinding anyway, if it has alot of hrs they probably will need replaced anyway, install pistons and sleeves, rod and mains
pistons
03-08-2013 15:16:23
 Re: 1988 Case 7120 - excessive blow by in reply to 430WLPG, 03-08-2013 15:09:55
Appreciate the input. They sell kits that contain: Pistons, Rings, Sleeves, Rod Bearings, Main Bearing Set, Head Gasket Set, Oil Pan Gasket.
When I did my Farmall M, I did not install the Main bearings, because I did an in-frame rebuild. Did all else though. Can you in-frame install the Main Bearings? If not, is there any harm done in skipping that.
430wlpg
03-08-2013 17:04:28
 Re: 1988 Case 7120 - excessive blow by in reply to pistons, 03-08-2013 15:16:23
Yes you replace the mains in frame. They were just roll out and roll back in
