Farmall Fast Hitch point measurement's
Dennis Barr
New User
anyone have the spec"s / measurement for the point part on the fast hitch?
wanting to cut a set out for a fellow and I don"t have any to go by.
Pretty sure the lite points are 2.5" height at the tallest & 1" thick. Do you have one to trace out?
I measured the hitch receiver and the point height the other day for a different thread. The small points are 2.30" high right behind the notch for the locking latch and the hitch receiver opening is 2.50" high for a .20" clearance. The large points are 2.80" high right behind the notch for the locking latch and the larger hitch reciver opening is 3.00" high for the same .20" clearance. Hope this helps but a tracing is probably needed to obtain the other deminsions which are needed, Hal.
when i was building the fast hitch to three point cov.i used 1 1/4 x 3 bar stock , that is the hard part finding it as i use to have to order in the min order and that was 120 feet as the 1 1/4 was special order where i bought steel . Back then new steel where i got it for was 28 cents a pound and it weighs in at 12.750# per foot. What i bought came to 1530 lbs
