Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: '49 Farmall Model C gov to carb adjust
gene bender
03-08-2013 01:50:12
You are holding the carb rod backwards as its closed when you hold it like you are doing. If it dies when the hand throttle is closed just set the idle speed screw on the carb NOT the one for idle mixture. It is possible the lever on the throttle shaft where the linkage fastens has moved on the throttle shaft. I did have one carb where that lever was loose and another one where that lever had moved it needed a new throttle shaft in the carb.
03-08-2013 07:15:38
 Re: '49 Farmall Model C gov to carb adjust in reply to gene bender, 03-08-2013 01:50:12
Gene... I will look again to make sure about the carb rod and I did notice the difference between the idle speed and idle mixture screws. I'll check the throttle shaft in the carb also. Great tips.
