live hyd question
Anonymous-0
putting m&w live pump on m wondered if i can go to xmas tree valve is there a relief valve in there? belly pump is gutted and used for resevoir have priority valve for power steering also if someone can tell me how to plum this up i would greatly appreciate it
I cannot tell you about the relief. It for sure needs one. The belly pump had one. From the output of the M&W I would put a relief regulator set to about 1200PSI. I would then direct the oil to the priority valve, then the Christmas tree input, then to the reservoir drain valve (in the reservoir bottom with a T fitting) from the Christmas tree return. A return must also be used on the regulator to allow over pressure oil to be returned to the reservoir. It can T into the return line to the reservoir mentioned above. Jim
