| Farmall & IHC Tractors Discussion Forum |
Topic: Jump start a positive ground 6v?
[Return to Forum]
| Author |
[Modern View]
| Joe in CA
03-07-2013 19:42:04
74.60.74.152
How does one do this? Does the cable go + to - between the jumper and jumpee? |
[Reply] [No Email] | |
| John T
03-08-2013 05:32:48
66.87.4.73
Re: Jump start a positive ground 6v? in reply to Joe in CA, 03-07-2013 19:42:04
| | Heres a summary: ALWAYS Pos to Pos Neg to Neg when jumping or charging, it dont matter which battery post happens to be tied to some huge hunk of iron as far as + to + and - to - rule is concerned... NEVER jump a 12 volt battery direct to a 6, Ive seen them blow up NEVER make a jump connections last connection near the battery especially around its top where explosive gasses can be present, I usually make the last connection on a good clean heavy frame member AWAY from the battery If youre using a Neg ground vehicle to jump a Pos ground tractor (still use rule above) dont let the vehicles make contact. Be safe, 12 vollts really makes her spin John T |
| SadFarmall
03-08-2013 03:00:26
112.213.173.139
| Positive to positive and negative to negative is exactly right. If you connect positive to negative (batteries in series) you will set up a 12 Volt system with two 6 Volt batteries. If you make the grievous mistake of connecting a 12 Volt battery to a 6 Volt battery nothing will work out. In series, you will create an 18 Volt system. In parallel, you may well cause an explosion in the 6 Volt battery. If you have a 12 Volt tractor, which uses two 6 Volt batteries, you can start your 6 Volt machine by connecting up to ONE of the batteries on the 12 Volt tractor. No harm will result. Remember, when jump starting, always connect in Parallel! Either vehicle can be negative or positive to ground and it won't make any difference to the jump starting procedure. I have jump started a VW Beetle with the Farmall M.
SadFarmall |
| FBH44
03-08-2013 02:20:54
64.85.214.246
| And to add scary stuff to this I had a 12 v batry explode on me once . Inside a Checy 1/2 ton, but it rocked the truck from side to side, thought I"d been shot with a 12 gage. (I"d just shut the truck off, and got back inside to re-start it.} I can"t imagine being on top of one as it blows. |
| Atilathehun99
03-08-2013 15:48:13
67.142.130.32
Re: Jump start a positive ground 6v? in reply to FBH44, 03-08-2013 02:20:54
| Our tiniest of elemental friends (hydrogen) packs a whale of a punch. |
| old
03-07-2013 20:39:56
209.86.226.11
| Always hook + to + and - to - unless your jump starting a 6 volt system with 12 volts and then you should NEVER hook a 12 volt battery to the 6 volt one or it could be the last thing you ever see because the 6 volt battery can/will blow up in your face. Plus if the 6 volt battery is so low it will not spin the engine over good chance it will not have enough to run it either. If you still want to do it hook the ground side as in + or - the same and then the other side right to the starter. But check and double check that it is out of gear |
| Janicholson
03-07-2013 20:02:06
74.60.94.18
| If you are doing it with 12 volts, and the tractor has a starter terminal that is accessible between the starter switch and the starter motor, just turn on the key and firmly touch the jumper to that conductor. (polarity doesn't even matter, as you are just spinning the starter and the starter motor always spins in the correct direction.) This eliminates issues with exploding batteries because the tractor battery and system are not involved. Ground the other jumper near the starter motor. (this will not work with ""booster Cables"" they are too small to operate any starter motor and can only be used to charge a like voltage battery for 15 minutes with the other vehicle. Good jumpers will have #2 wire in them. Jim |
| CNKS
03-08-2013 13:11:17
216.144.104.128
Re: Jump start a positive ground 6v? in reply to Janicholson, 03-07-2013 20:02:06
| Jim, Only problem with that is that sparks are too close to the gas tank and sediment bowl for me. I would rather attach the positive first, then the ground somewhere else. Usually I revert to cranking, in spite of all the broken arms I have read about on this forum. |
| sflem849
03-08-2013 16:55:46
69.197.84.39
Re: Jump start a positive ground 6v? in reply to CNKS, 03-08-2013 13:11:17
| Quoting Removed, click Modern View to see
I prefer a chain. 8) |
| DeltaRed
03-07-2013 19:49:44
71.208.220.227
| POSITIVE to POSITIVE,NEGATIVE to NEGATIVE.Regardless of ground position. |
| 504
03-07-2013 19:58:51
199.127.54.155
Re: Jump start a positive ground 6v? in reply to DeltaRed, 03-07-2013 19:49:44
| And make sure that the two vehicles do not touch. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
