Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: '49 Farmall Model C gov to carb adjust
[Show Entire Topic]  [Return to Forum]
Jimmy in TN.
03-07-2013 19:18:53
71.88.3.210
When I set the throtle all the way up then hold the carb rod up to match the yoke to the gov.rock shaft I have to run the yoke all the way out to the end of the carb, rod to get it to match, then when I start it it will not idle down, it wants to run wide open,I have a manuel and have read every thing I can find on here, I have had the gov.of several times replaced thrust bearing, spring,little spring on the end of the gov. shaft.I am at my wits end. any ideas? thanks.
[Reply]   [No Email]
mpbarber
03-08-2013 07:28:23
67.142.168.26
 Re: '49 Farmall Model C gov to carb adjust in reply to Jimmy in TN., 03-07-2013 19:18:53
Jimmy... Sounds like you have the opposite of my problem. It looks like I'm going to have to turn the yoke towards the carb.
I haven't taken the gov apart but I've read the instructions a couple of times and one of the things mentioned was making sure that the large spring was not only hooked in the correct hole on the rock shaft, there are 2, but also that it was facing the right way since apparently the hook can catch on something if it's put in "backwards".
Can you manually operate the gov from the carb side of the engine and get any control over the engine speed? That at least would tell you that the gov is not restricting the throttle movement.
Other than that, I'll defer to the other guys on here because it's clear to me that they know a lot more about this than I do.
good luck,
mike
[Reply]  [No Email]
Jimmy in TN.
03-08-2013 11:40:46
71.88.3.210
 Re: '49 Farmall Model C gov to carb adjust in reply to mpbarber, 03-08-2013 07:28:23
the spring you mentioned comes with both hooks turned the same way, on my old one the hooks were turned opsite one another but they do not come that way now.
[Reply]  [No Email]
mpbarber
03-08-2013 16:02:59
67.142.168.26
 Re: '49 Farmall Model C gov to carb adjust in reply to Jimmy in TN., 03-08-2013 11:40:46
What does your manual tell you about that spring. Mine has a diagram showing the spring and the direction of the hooks. Does yours show 2 holes on the rockshaft lever? My diagram shows an "A" and a "B" and there is a chart showing what hole to use.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
