Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 404 resistor wire
hayfarmer
03-07-2013 17:51:29
Was the wire used to bi pass the resister for starting? If so it is no longer needed.
hrtuffenuff
03-07-2013 17:56:13
 Re: 404 resistor wire in reply to hayfarmer, 03-07-2013 17:51:29
yes, this is a original wire.I was never sure what they were for. I know that they are on several models.
Bob M
03-07-2013 18:12:50
 Re: 404 resistor wire in reply to hrtuffenuff, 03-07-2013 17:56:13
You can eliminate the resistor wire and it should work fine.
The resistor wire was used originally so a 6 volt coil could be used on a 12 volt tractor (it dropped primary voltage to the coil to 6 volts). However when the starter was engaged the resistor wire was bypassed so the coil received full battery voltage during cranking. This gives a hotter spark while cranking and thus more reliable starting - especially as plugs, points, etc became worn.
Just keep your 404 in good tune and you should have no starting problems.
Copyright © 1997-2015 Yesterday's Tractor Co.
