| Farmall & IHC Tractors Discussion Forum |
Topic: C301 out of an 806 two mystery bolts in head
[Return to Forum]
| Author |
[Modern View]
| Mitchel - Farmall 460
03-07-2013 15:00:35
166.205.55.33
I am finishing up putting the motor into my daughters 460. I got the motor out of a farmall 806. Here is my question. There are two 5/16 bolts in the left side of the head. They are dead center between #3 and #4 valves. Bolts were only finger tight when I take them out the bolt holes go all the way through and you can see valve stems. Looked at my c221 that came out of the 460 and there are no holes. What bolts to these? Am I missing something? I know a picture would be worth a thousand words but I can't get one to upload. Anyone have an idea? Thanks, Mitchel |
[Reply] [No Email] | |
| pete 23
03-07-2013 18:56:22
74.47.40.242
Re: C301 out of an 806 two mystery bolts in head in reply to Mitchel - Farmall 460, 03-07-2013 15:00:35
| I should have added it is where the coil was mounted on other engine applications, like when the BD (black diamond) engine was used in trucks. You should see a flat spot on the 460 head where the bolts would be but were not used in that application. Also, if you look at a lot of the blocks you will see a casting indentation near center of block where the throttle linkage would have been run through the block when used in a truck. Just thought I would throw that in. I remember when we got our first 560 at the dealer ship, I said , they put a truck engine in her. |
| Mitchel - 460 Farmall
03-08-2013 03:06:07
98.66.194.22
Re: C301 out of an 806 two mystery bolts in head in reply to pete 23, 03-07-2013 18:56:22
| | thanks for the info, the only reason I was questioning the holes was because they are drilled and tapped all the way through. You are right about the 221 head it has the same flat places but no holes drilled or tapped. p.s. Got it running last night and it sounds great. Now I just have to finish putting everything back together. Once again thanks for the info. |
| pete 23
03-07-2013 17:43:19
74.47.40.242
| For the gas tank mounting bracket on the 806. |
03-07-2013 17:19:07
98.66.252.50
| Coil clamp is bolted closer to the front of the head. I don't know what these are so I am going to put some washers on the bolts cut me a piece of gasket material to go under the washers and tighten them down so oil want leak out. Maybe this will work. Thanks for the replys. |
| Allan In NE
03-07-2013 17:04:01
148.66.88.254
| | Yep, That's where the coil clamp bolts on. Allan |
| cole in mo.
03-07-2013 16:22:15
65.255.149.240
| Might be where the coil bolts on. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
