TractorLinks.com
Show Parts for Model:
Re: farmall c
Kristof
03-07-2013 13:00:55
Jep, checked for that aswell...
But I"ve been thinking, maybe the problem lies with my governor... Since my sparkplugs remain dry while my carb is overflowing. Normally when an engine is flooded the sparkplugs should be soaking wet right? What if my gas-valve is regulated normally while I crank the engine but once it fires up it closes the valve? Tomorrow I"m gonna try cranking the engine while operation the carb directly. Hope this will give me some results.. What do you think Gene?
gene bender
03-08-2013 03:02:29
 Re: farmall c in reply to Kristof, 03-07-2013 13:00:55
Hey are you sure Celien hasnt got anything to do with the problem. You say the engine runs how fast is it running when it dies and how long does it run before it dies.It has to be a carb or gas flow problem with the carb leaking. Cause if it dies after starting and running its fuel.
gene bender
03-08-2013 02:52:56
The gov doesent have anything to do with gas running out of the carb. You have got to have a problem with the float as it and it only controls the gas flow to the carb. When you say gas runs out of the carb where does it run out the throat or the weep hole in the bottom.
Kristof
03-10-2013 01:59:33
 Re: farmall c in reply to gene bender, 03-08-2013 02:52:56
I was thinking maybe there where 2 problems occuring at the same time.. It always had some seepage from the weep-hole whenever I flooded it or when I shut it down. I figured this was normal... I tried the linkage-thing I told you about earlier yesterday. I managed to keep her running like 10 seconds longer than just firing up. I"ll try to twitch the carb tomorrow like you said, that is if Celien will leave me alone long enough :-P. There always seems to be more urgent bussiness with her 2 rabbits than with my 4 tractors, go figure? I"ll keep you posted!
