| Farmall & IHC Tractors Discussion Forum |
Topic: stuck hubs on 650
[Return to Forum]
| Author |
[Modern View]
| Nathon
03-07-2013 10:01:33
216.227.55.31
In an effort to put new seals in the rear axles of my 650 I am trying to remove the hubs from the axle shafts. I have put heavy reinforced tubing across the face of the hub and bolted where the weights go. I am using the 1" center bolt to push on the tube. This creates much force but to no avail. I have drilled a hole vertically through the cast into the splined shaft to accept penetrating oil. I have heated the hub with a rosebud torch. And of course the sledge has been involved. Any other ideas are welcome. Thanks! |
| Russ600
03-07-2013 13:16:23
216.238.232.187
Re: stuck hubs on 650 in reply to Nathon, 03-07-2013 10:01:33
| | Hi Those hubs can be tough to get off, I have a 30 ton puller that I have destroyed taking a 650 hub off. I also used a rosebub and sledge with some sucess, but I have broken a hub doing that. I have a friend that works on 9 series a lot and he pulls tha axles and hub together and takes them to a machine shop that has a 100 ton press to get them off. Even with that big press there has been difficulties. I have replaced my puller, that has worked on most of the hubs, but if I get another on the is tough to pull it will go where there is a big press. I guess it just depends on how bad they are stuck. Good Luck Cheers Russ |
| sflem849
03-07-2013 11:48:53
69.197.84.39
| Pull the PTO and remove the axle/hub assembly. Then put the whole thing in a press and press them off. I have read some pretty good horror stories about this project. |
| todd765
03-07-2013 11:29:38
206.246.135.128
| I had a simular problem on a w6. Took some scrap metal and formed a wrap around the hub that was open on top. filled with charcole and let it bake. Through out the day I would take a sledgehammer and hit the hub on back side. Finally after it started to cool one time I hit the hub with the add presrue like you have describe it popped and broke loose. Hope this is helpful |
| rustred
03-07-2013 10:30:05
72.172.100.113
| if they ae stuck as you say then may need to remove complete axle and find a machine shop with huge press. that 1" bolt has little effect on some thing that size that is siezed. myself i would use another tractor and chain and give it some jerks once hot. long as you know whats involved with the danger and safety of doing this. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
