Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: one wire Delco install question,Any Help?
John T
03-07-2013 07:46:59
If its a ONE WIRE alternator its big output stud wires to the Load (NOT battery/starter) side of the ammeter. Thats where the wire that used to go to BAT on the Voltage Regulator wired, but Id replace it with a new 10 Gauge wire......
If you hooked up Load and Bat and other wires on the old VR wiring you could be backfeeding the coil, I cant say sitting here how you have things wired up now.
Id unhook and not connect any old VR wiring and simply run a wire from the alternators output up to the Load side of the ammeter. Absent any LOAD terminal on an old VR Id wire all loads (lights and ignition etc) to the load side of the ammeter, same side the alternator now wires to. )
If you changed from Pos to Neg ground Id also swap coil wires side to side, you want the coils - to the distributor for Neg ground.
John T
Too Far Gone
03-07-2013 11:57:09
 Re: one wire Delco install question,Any Help? in reply to John T, 03-07-2013 07:46:59
Im pretty sure all Im just back bleeding juice through the ignition after wiring stuff up to run.I believe unhooking from it and running a heavy wire to ammeter will be my next move.It already has the coil hooked up the right way,as it was already a 12 volt system with the ol generator,but it has been switched around to Neg Ground.I had an old 74 chevy truck one time I couldnt kill even after unhooking the battery after the key switch had gone bad and stuffed my coat in the carb to choke it down,Thanks for the helpful ideas fellers!Gotta get offa here and go look at bulls.Thanks for now
