Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Farmall B
[Return to Forum]
todd 765
03-06-2013 17:41:43
70.194.136.122
Bringing back to life tractor been sitting for several years. Finally got it to run but have to have the carborator choke 1/4 pulled for it to run. Any ideas?
[Reply]   [No Email]
mkirsch
03-07-2013 11:06:52
64.80.110.74
 Re: Farmall B in reply to todd 765, 03-06-2013 17:41:43
Manifold leak? Maybe it's leaking around the carb/manifold flange?
[Reply]  [No Email]
todd765
03-07-2013 08:30:20
206.246.135.128
Manifold is new, Carb has been cleaned, sediament bowl assemble is new. Have check flow out of carborator. I have installed the carb kit and with kit replaced the seal on butterfly. Any more ideas problem still their. Sparkplug,wires,cap, points, condensor and rotor new.
[Reply]  [No Email]
Lmack
03-06-2013 19:32:15
24.131.58.167
Let it run for a while as well as all the other suggestions. You may have to drain the fuel bowl on the carb sevral times to get a good flow of fuel. A good cleaning will do the job, but it may just need a good flushing out. Be sure your fuel is fresh. Look for leaks in the intake manifold. A leak will make it run lean.
[Reply]  [No Email]
old
03-06-2013 18:28:08
209.86.226.19
That could be a few things wrong. Poor spark will cause that. You need a blue/white spark that jumps a 1/4 inch gap or more. #2 you need a good steady flow of gas out the carb drain plug for a few minutes. #3 you need a clean air cleaner with the correct amount of oil in it. #4 you need enough compression to pull the fuel into the cylinders as it should. Any one of those not being as it should be will cause that problem
[Reply]  [No Email]
teddy52food
03-06-2013 18:03:27
184.94.175.179
Clean the carb.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
