Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 404 timing better but no start.
RLO
03-06-2013 16:58:05
I see there is a lot of movement in the rotor. It has almost 3/16" slop & you can move it back & forth real easy. The gear looked okay. I think its the piece the rotor attaches to ... the cam? Is there a rebuild kit? Thanks.
RLO
03-06-2013 17:23:43
 Re: 404 timing better but no start. in reply to RLO, 03-06-2013 16:58:05
It does not snap back it's slop something is worn. I've read everything over and over & followed it. Believe me I appreciate it. I do have the shop manual, parts manual, and operators manual. Thanks for your time.
kevinj54
03-07-2013 04:44:18
 Re: 404 timing better but no start. in reply to RLO, 03-06-2013 17:23:43
Tear it down and inspect as Jim said, while you are in there make sure the shaft and bearing is in good condition.
Janicholson
03-06-2013 18:38:16
There is a centrifugal governor in the distributor. It has weights and springs that advance the timing as the engine RPM increases. The rotor should move through a 20 to 30 degree arc. But the springs must pull it back. Take the points out, then the backing plate. The springs and weights will now be visible. I bet the springs are toast, or the shaft is way sticky on the input shaft. Jim
kevinj54
03-06-2013 17:01:53
You are moving the advance unit. It should snap back when you let go. (NORMAL). Go back and read what these guys have told you, follow it, and it will be timed correctly.
You may want to buy a manual for your tractor also.
Copyright © 1997-2015 Yesterday's Tractor Co.
