Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: change 282 d to a 310 d in a 560d
03-04-2013 05:42:35
Yeah, pretty much everything from the bell housing to the front bolster on a 706D is just "slightly different" enough to make conversion from a 282 to a 310 a total pain in the rear.
The frame bolt pattern and spacing should be the same between the 560 and 706. You should be able to hang the engine in the frame rails using standard 706 front and rear plates.
Beyond that I really don't know. What are you going to use as a flywheel, clutch, starter?
The radiator outlet is on the wrong side too, IIRC.
roger hall
03-04-2013 08:39:44
 Re: change 282 d to a 310 d in a 560d in reply to mkirsch, 03-04-2013 05:42:35
mkirsch----you have taken me to my first unknown!--the whole key to this project is that fit-i know there is a flywheel and ringgear in there-the starter cranks it now, as for the clutch --at worst stay with 560 spline--after that fit is made,it:s all cosmetics-- one prob at a time--i"m going out with ruler ,paper and camera and see what i can see---thanks-all help apreciated
