TractorLinks.com
Show Parts for Model:
Re: IH 300 Utility Starting Issue
Ben Pung
03-04-2013 05:04:39
Thanks Mark. I want to make sure I'm clear on the testing procedure for the ignition coil.
So on the battery side of the coil, I just turn on the key and use my test light to touch the wire coming to the ignition coil (touch the black test lead to the block, red test lead to the connection on the coil). If it's on, I have power. Is it possible that I have power, but not enough? do you know what the volt meter should read here (or a rough range)?
For the distributor side of the coil, I'm not clear on how you are saying to test this. Can I just take my tester and again touch the black lead to the ground, then quickly touch the little arm in the distributor cap that spins and makes contact with each point? If I get a reading when I do that, that means power is coming through the cap and getting to the points right? I just cont confused when you were describing jumping the points with a screwdriver. I'm not sure what you mean. Can you try and clarify?
Thanks a lot for the help.
Mark Robke
03-06-2013 16:54:39
 Re: IH 300 Utility Starting Issue in reply to Ben Pung, 03-04-2013 05:04:39
Ben, since you have a 12 volt system you may have a resister inline from key to coil, if the coil is origional 6 volt,if it is 12 volt no resister. the resister could be open (voltage in none out). What I meant about the points was you can make the coil spark by opening and closing the points with a screwdriver- key on. The points open and close and you should see a spark when you open and close points or while cranking engine with cap off, in neutral. You have to have a 12 volt test light to check voltage from keyswitch to coil. you could check voltage to points if they are open. A bad condensor can short points to ground = no spark. You cannot check the rotor button (which you called little arm that rotates inside cap for voltage : you would need to check it for continuity with an ohmmeter. Let me know if any of this helps or if you get it running.
MARK
Mark Robke
03-07-2013 05:41:52
 Re: IH 300 Utility Starting Issue in reply to Mark Robke, 03-06-2013 16:54:39
Ben,there is a thread above : no spark at points; read John T"s link to troubleshooting ignition; it"s very good and should help you.Mark
Ben Pung
03-09-2013 12:04:59
 Re: IH 300 Utility Starting Issue in reply to Mark Robke, 03-07-2013 05:41:52
OK, I wanted to give an update on this. You have all been very helpful and I really appreciate the advice. I had my neighbor come over and help me last night. He's way better mechanically than I am, plus I had a hard time trying to check spark when turning the key myself. So he came over and we started with spark. Was getting 12V to the coil. Points looked good. Rotor button looked fine. Turns out I was getting spark out of the plug. Either I wasn't getting a good ground or couldn't see what I was doing when I tried it myself.
So, we verified that the choke was opening up when I pulled out the knob. Cranked on it and still got nothing. So we took off the air intake hose and blew a bunch of starting fluid into it and cranked the crap out of it and it eventually started. I let it run for a couple hours and moved the throttle around. I added some liquid heat to the gas so I wanted to make sure that was all run through the system. I pulled it into the barn and let it set over night. This morning I went out and tried it and it fired right up. It's like 50 degrees today, so it's not a good test of if the cold is part of the problem. But, I have no idea what happened last weekend. Maybe something was stuck in the carb and I just happened to run out of gas when I tried to pull my truck by coincidence? I don't know. I know that it appears to be fuel related so I'm going to get a carb kit and will go through the carb either this summer, or sooner if it craps out again on me. So, long story short, my theory for the moment is that something was stuck in the carb and got blown out of there once we got it running using starting fluid. If anyone else has another theory I'd love to hear it.
Thanks again for the help.
