Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: IH 300 Utility Starting Issue
LynnKaufmann
03-02-2013 19:29:17
I would suggest installing a Pertronix Igniter ignition replacement system for about $90.00. Very easy to do and now you do not have to worry about the points and condenser. This way the ignition system will give you a very good spark. Only thing additional is be sure your coil will produce a good ignition spark. Do not use anything other than a stock coil with this system. You can check the coil by taking the wire going from the coil to the points and very quickly touching it to ground and then removing it from the ground (opening and closing the circuit), just like the points would do. If you get at least a 1/2" spark out of the coil wire (being held with this gap from a good ground), then the coil should be fine. Boy does this help my 300 with starting in all types of weather.
