Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: change 282 d to a 310 d in a 560d
DeltaRed
03-02-2013 17:33:05
If you mean a 310 german diesel from a 706,then it would be a lot of work.I do know you will need to change the throttle linkage,probably the air intake.Dont know if it will bolt to the bell,or if the clutch will work.If the 310 is longer,then you will need to stretch the frame/hood...A 310GD in a 560,That would be awsome!
roger hall
03-02-2013 18:46:29
 Re: change 282 d to a 310 d in a 560d in reply to DeltaRed, 03-02-2013 17:33:05
i picked up a 560 --282d--today at a sale--i have a 715 combine with 1500 orig hours--310gd--i know the 706 has the 282 and the 310gd--so somehow in my mind that should match up somehow in the 560
The tractor vet
03-03-2013 08:02:06
 Re: change 282 d to a 310 d in a 560d in reply to roger hall, 03-02-2013 18:46:29
Can it be done ?? not with out a ton of work. Yes the 310 and 282 were in 706's BUT even doing a swap in them is a ton of work . Frame rails need changed fuel lines linkage i do believe the hoods are different . BUT hay anything is possible . Look what i am doing at the moment putting a 8.3 Cummins into a 2150 oliver fwd . Yes we have had to do some Barn Yard engineering and some fab work due to the ft. drive shaft and pan issue but that was easy and all that is left is four motor mounts . everything else was off the shelf bolt ons. And a lot of phone calls and running after stuff. Spent more time doing that then twisten wrenches.
