tubing sleeve
Oldiron29
Been working on a TD-6 I have to replace a 3/8" tubing. I got the tubing it is the brass sleeves that are the problem. They are not regular compression sleeves they have a shoulder on one side. Do these have a special name? Does anyone have a good idea where to find them?
Thanks oldiron29
Those are called 'break-away' fittings. The compression sleeve is machined as part of the nut. When the nut is tightened, the seal is formed, and the sleeve breaks off. Any good brass supplier should be able to get them for you.
Fritz, That is it! I see pictures on line and yes that is what I need. As you said Good Brass supplier That is my problem, I don't Have a good supplier. Breakaway sleeve got it.
Thanks oldiron29
I believe the current part # is 222-503 @ your Case IH dealer. Reasonable, @ about $2.00.
