TractorLinks.com
Show Parts for Model:
Re: F20 water in oil
Skaning
02-23-2013 19:48:41
The rings at the base of the sleeves are a good suspect here. The problem though may actually be the sleeves. The seal area is at the bottom of the block and all of the crud, rust mainly piles up in that area and stays wet. Results in a heavy corrosion ring around the sleeve just above the seal. In time it will work it's way down to the seal surface on the sleeve. It's a real problem with older southern tractors where they never used antifreeze or corrosion inhibitors.
