TractorLinks.com
Show Parts for Model:
Re: F20 water in oil
robgIN
02-22-2013 19:13:29
If you are getting water in the oil in an F-20 about the only place it can be coming from is past the sleeve o-ring.Could be a cracked block but most likely o-ring. Did you have the sleeves out ? Any water from head gasket or cracked head is unlikely to get in the oil, unless you get a lot in the cylinder and some trickles past the rings.As said before, just take the inspection covers off and look around the bottoms of the sleeves with a mirror and you will probably find the leak.
Daninsc
02-22-2013 20:16:12
 Re: F20 water in oil in reply to robgIN, 02-22-2013 19:13:29
I didn't take them out, I hadn't looked in my Manuel but are they hard to replace?
robgIN
02-23-2013 07:21:37
 Re: F20 water in oil in reply to Daninsc, 02-22-2013 20:16:12
it depends, all of them I have removed have been stuck like a son of a gun. I have a sleeve puller and usually I have to tighten the nut on the puller as tight as I can get it and then hit the bottom plate with an air hammer to get them to pop loose.
Old-F20
02-22-2013 21:05:53
they're a ton of fun. pull the head, then pull th eoil pan and drop the pistons out the bottom of the sleeve. if its 4 inch bore they will just squeez out the top, then get a sleeve puller and pull them all out. its alot of work for a 5 dollar o-ring
