TractorLinks.com
Show Parts for Model:
Finally put the 300 back to work
Zachary Hoyt
02-22-2013 19:12:21
I plowed a little snow tonight and will plow out the mill tomorrow. I am very glad to have it back up and running even with the noise. When I wear my noise reduction earmuffs I can't hear it but I can still feel it in my feet a little. I got a seat cushion from Surplus Center along with some other stuff and I am very happy with how much more comfortable the seat feels. I am also hoping it will boost the tractor's self esteem and help it not to break down as often. Thank you again to all of you who have been giving me advice during the repair saga of the last 7 weeks.
Zach
rankrank1
02-23-2013 19:03:28
 Re: Finally put the 300 back to work in reply to Zachary Hoyt, 02-22-2013 19:12:21
Thanks for the pics. That rig oughta plow some snow for sure. Will you ever use a bucket on the loader?
Zachary Hoyt
02-23-2013 19:14:26
 Re: Finally put the 300 back to work in reply to rankrank1, 02-23-2013 19:03:28
I would use a bucket if I had one, but the loader came just as you see it on a parts tractor a couple of years ago. I have a bucket and forks on the Massey 35 that I do use, and I used that tractor to plow snow while the 300 was apart but it spins out a lot sooner and will not push nearly as much snow with tire chains as the 300 will push without them.
Zach
Notjustair
02-23-2013 10:03:53
That old sucker best be earning her keep if she knows what's good for her. That's enough down time for at least 7-10 years!
rankrank1
02-23-2013 09:49:07
Zach - Is that the same loader you had on your previous h?
I would be interested in seeing a frontal and side views of tractor with that loader mounted. (If you have posted those loader pics before then I must have missed them).
This post was edited by rankrank1 at 09:49:30 02/23/13.
Zachary Hoyt
02-23-2013 17:52:34
 Re: Finally put the 300 back to work in reply to rankrank1, 02-23-2013 09:49:07
As MIster T said the loader hooks up just the same but since I didn't have the IH spacers I used some spare drawbar bracket parts from an H parts tractor. The box steel pieces already had the correct bolt holes drilled through them and the angle iron pieces were bent on this drawbar so I had not been able to sell the drawbar brackets whole. I just had to go to the hardware store and get some 5/8x10" bolts and everything was fine. At first I got galvanized carriage bolts but I could only get the nuts onto them if I used grease and a lot of force and I could not get them all the way tight. After that I found some regular grade 5 hex head bolts that worked a lot better, but I still have to replace the carriage bolts on one side. Zach
Angle Iron
02-24-2013 05:44:54
 Re: Finally put the 300 back to work in reply to Zachary Hoyt, 02-23-2013 17:52:34
MisterT
02-23-2013 12:04:40
The McCormick #31 loader will fit right on the 300 through 450 tractors just the same as it fits on the H and M, BUT, a spacer is required between the rear axle and the mounting bracket of the loader. The spacer is required to accomodate the extra length of the hundred series tractors. At one time, the spacer was available through IH.
Zachary Hoyt
02-23-2013 10:46:10
I will get some pictures this afternoon and post them this evening if not before.
Zach
Janicholson
02-23-2013 05:50:44
All straight cut gears (bevel and spurr) make noise. There are some very expensive gears used to drive helicopter rotors that are computer profiled. they still make noise. The purpose is to gain reliability in a single point failure location. (having the rotor stop is not good) The straight cut gear is still one of the highest efficiency power transfer available.
It will be OK in my opinion. Jim
Zachary Hoyt
02-23-2013 10:45:20
 Re: Finally put the 300 back to work in reply to Janicholson, 02-23-2013 05:50:44
Thank you, that is interesting to know. I know that all three of the Allis Chalmers tractors I have had in running condition(two Cs and a B) have been quite loud in third gear especially. I am much happier to have the 300 working and making noise that sitting around in pieces quietly.
Zach
rankrank1
02-23-2013 09:45:02
Yep most of my old antique tractors make some slight rear end noise. A little is noise is okay. However if you want to listen to something that will drive you nuts then play some videos of some old Oliver 77 or 88 models. The extreme whine they made brand new would have been unpleasant for me to have to get used to. (note: I am not bashing Oliver as I love a lot of their stuff).
The Red
02-23-2013 05:10:23
Congrats Zach!
DeltaRed
02-22-2013 19:29:24
It's a great feeling to be 'back in business'! Congrats!
