TractorLinks.com
Show Parts for Model:
Re: 706 international gas
Janicholson
02-22-2013 17:10:35
As Pete indicates. Probably a hydraulic lock (fluid in the combustion chamber, could be gasoline, or coolant, or water down the muffler.
In all cases find out what it is before cranking it with the plugs in. If a piece of metal from ? gets on top of a piston, it will destroy the engine if cranked (especially if pull started. Were it mine I would look in each cylinder with a bore scope if there is no fluid in the cylinders. I also would make sure to assess the type of liquid in the chamber when getting it to turn over. Insight there is important. If it is frozen, water. (probably the best thing to find) you may need to heat that cylinder with a propane torch till it melts out.
Bent rods broken piston rings and bent valves can be easily manufactured by an engine close to TDC being forced over the top. Jim
tractor300
02-22-2013 18:15:41
 Re: 706 international gas in reply to Janicholson, 02-22-2013 17:10:35
Getting metal on top of a piston doesn't happen too often, but it can. Dad had a brass screw come loose from someplace in the carb on an H,and got sucked up in engine. Fortunately it was small and didn't do major damage. Sure made a loud hammering sound for a small object. He got it out through the spark plug hole. Piston was beat up, but no other damage.
