Need bearing numbers
Ron W
I need the following bearings converted to modern bearing numbers from IHC part numbers please:
35420-D
ST-208-B
23232-D
23681-D
18567-D
10701-D
When I come across an IHC bearing that NAPA can not cross, I measure the inside and outside diameters and width. My local NAPA store can then look up new bearings based on those measurements.
Well, I am in suburbs of Detroit. There is no real old fashion Napa stores left. When I call them or go in, they say "what vehicle is it off from", and when I tell them, they tell me it doesn't come up in their computer. So I am out of luck. That is why I am asking this website for help.
35420-D = ???
ST-208-B = 205S
23232-D = ???
23681-D= 206S
18567-D = 2063R
10701-D = 205
Bower/BCA #
I hope it is correct!!
(quoted from post at 22:36:17 02/22/13) I need the following bearings converted to modern bearing numbers from IHC part numbers please:
If I'm reading a 70's era IH bearing book correctly:
[size=18:418ec1f1eb]35420-D[/size:418ec1f1eb]=New Departure SS 7501
[size=18:418ec1f1eb]ST-208-B[/size:418ec1f1eb]=West Pullman (IHC) PC 225
[size=18:418ec1f1eb]23232-D[/size:418ec1f1eb]=Aetna A 716
[size=18:418ec1f1eb]23681-D[/size:418ec1f1eb]=New Departure 7506
[size=18:418ec1f1eb]18567-D[/size:418ec1f1eb]=Nice 5015-1 (Note says now use BCA/Fed. Mogul 2063-16. No other IH number crosses to 2063-16 in this book.)
[size=18:418ec1f1eb]10701-D[/size:418ec1f1eb]=New Departure 3205
AG
ive got some big bearing books but they are broke down into bearings for each tractor. are these numbers all off one tractor? if so which one?
Go to Federal Moguls ecatalog. It has a cross reference where you can just enter your old number and if that doesn't work you can enter the dimensions you need and it will list like 10 bearings either exactly or within a few thousands one way or another.
No offense, but if you're in the suburbs of Detroit, there must be a shop that deals only in bearings somewhere nearby.
Yes, They do. They want the new IHC numbers, suchs
as the ones with numbers-R-(2-digitnumber). They
hhave no way of cross-refferencing to the old IHC
with numbers-DX or such. It is very frustrating as
they will not spend time to help you out.
A real bearing house like Motion or Detroit Ball will MEASURE them and find a bearing for you, At least they will in Grand Rapids.
(quoted from post at 10:40:31 02/23/13) Yes, They do. They want the new IHC numbers, suchs
My bearing store is the exact opposite. They can cross the very first number, but they struggle when you give them an R1 etc number. They are pretty helpful.
(FWIW) CIH availability and current part numbers according to Messicks' website (which has been incorrect on occasion):
35420-D-----I couldn't find any info.
ST-208-B-----Still available from CIH/current part number.
23232-D-----I couldn't find any info.
23681-D-----Subs to ST211. ST211 is still available from CIH.
18567-D-----Still available from CIH/current part number.
10701-D-----No info. It does show 10701DA subbing to ST208B, and as above, ST208B is still available.
A mid 80's supercedence book shows 10701D subbing to ST225B. ST225B subs to 210041, and is still available from CIH.
Adding to my previous list with sub numbers from above (again, according to the old bearing book):
[size=18:fe580e757c]ST211[/size:fe580e757c]=West Pullman (IHC) PC 230.
[size=18:fe580e757c]ST225B[/size:fe580e757c]=West Pullman (IHC) C 225.
AG
