Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: SMTA
Mark Alayne
02-22-2013 06:29:41
I am trying to figure out what I have so I can buy the right parts as I work on this tractor. I have the camshaft gear driven hydraulic pump. My PTO only works when clutch is disengaged. Does this means I have a stage 2 Super M? How can I tell if mine is a TA? Will the serial/model number tell me?
D Slater
02-22-2013 14:00:17
 Re: SMTA in reply to Mark Alayne, 02-22-2013 06:29:41
Where the center housing bolts to the transmission. If you can only see 2 mounting bolts on the outside of the housing. One near the top on each side. Its not a T/A tractor chassis. If it has 3 bolts mounting the starter on. Its a stage 2 SM or t/a tractor if the center housing has more than 2 mounting bolts visuable. Unless its a diesel, then it could be a stage one SM or a MD that someone put a hydraulic pump on. 2 bolts mounting the starter, = a stage one SM or a M someone mounted a hydraulic pump to.
Armand Tatro
02-22-2013 07:14:20
As I understand it either PTO was aviable on the SMTA. and the TA option could deleted. Some of this information would hav been in the SN# code. Armand
Dave H (MI)
02-22-2013 06:58:32
Well, if you have a long handle on the left side with a squeeze grip that only moves front to back you probably have a TA. If you have a similar handle to the right of the seat you probably have IPTO (but it doesn't sound like it). The hood could say anything and mean nothing. Serial number would help if the tag is there, readable, and hasn't been swapped out. Casting dates would help if you want to jot some down and post them here. If you post a couple of really good pictures of the tractor I could tell you if it is a SMTA. Been driving one for 12 years almost daily in the summer...think I could tell. :)
CNKS
02-22-2013 06:53:07
Post the serial number -- if you are going to order parts it will help you and whoever you order from if you purchase a parts book. That is particularly true with CaseIH. All you have to do is call them and give the part number, they do not need to know what it fits -- it is in their computer and they can tell you in a couple of minutes whether it is in stock or has to be ordered.
Copyright © 1997-2015 Yesterday's Tractor Co.
