Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall H connecting rod alignment
C Brown
02-22-2013 05:53:27
is it like this in video
CharlieNJ
02-22-2013 06:02:06
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 05:53:27
Yes, that's one way to do it
C Brown
02-22-2013 06:03:59
 Re: Farmall H connecting rod alignment in reply to CharlieNJ, 02-22-2013 06:02:06
are you in the southern nj area any shops you reccomend
C Brown
02-22-2013 06:34:52
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 06:03:59
how imperative is the alignment, i called a machine shop and they basically told me not to worry about it unless engine suffere major damage? Do alot of guys actually get this checked when yhey do rebuilds?
CharlieNJ
02-22-2013 06:42:52
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 06:34:52
Take his advice. The H motors isn't a high speed engine, and unless it was stuck and someone pounded the pistons out, I would say just put 'em back. But, depends on your level of perfection, and your wallet. When I install a rod and piston, I always turn the crank with a wrench, by hand, and feel for any binding, do it for each piston. Can also check the piston height with a dial indicator on a mount, to see if any are "short".
CharlieNJ
02-22-2013 06:24:02
Yep, SJ, as far South as you can go. Where are you? Shops for what, parts, rod checking?
C Brown
02-22-2013 06:37:17
 Re: Farmall H connecting rod alignment in reply to CharlieNJ, 02-22-2013 06:24:02
Bridgeton, have all parts just needing shop for alignment
CharlieNJ
02-22-2013 06:45:08
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 06:37:17
I'm in Cape May. I have used Bridgeton Spring's machine shop several times. They are pretty good, give them a call too.
Regards,
Charlie
